stergi
#1 Posted : Monday, June 15, 2015 12:03:27 PM(UTC)
stergi
Is a little bit weird but when i choose Nvidia Gt750m as laptop's default GPU, render time goes to 20ms (more or less).But when i choose Intel Grephics card render time drops to zero.Has anyone addressed that issue before?
Best regards
#2 Posted : Monday, June 15, 2015 12:44:29 PM(UTC)
On most laptops with both Nvidia and Intel graphics they use Optimus for graphics sharing.
When Nvidia is selected, this will first process everything on the Nvidia GPU then send it to the Intel graphics before being displayed.
This adds some latency which can be seen by the 20ms render time.
The Nvidia card has more GPU processing power, so you should be able to do things like complicated chroma key virtual sets ec
without the render time rising too much, whereas if you used just the Intel graphics, the render time may start small but will quickly
jump up if using a lot of complicated inputs.
Hope that helps.
stergi
#3 Posted : Monday, June 15, 2015 12:50:40 PM(UTC)
stergi
Hope that helps.
Martin thanks for your asap responding.If i got it right, i shall use Gt750 over the Intel Graphics, regardless the 20ms latency.
Best regards
