I just registered today for the SD version and am needing to capture three video sources via usb capture devices. However, when connecting the third card, I get the error code that says there is a problem with the third source. So far, I have closed every input and verified that the usb capture device is working as long as it is one of the first two, then a device that was previously not working will not load. It acted as if it were the free basic unit that has a limit of two captures. I restarted....no luck. I reinstalled...no luck. I deleted, restarted and reinstalled.....no luck. I thought it might be an issure with using more than two of the same usb capture device, so I installed different model of device. Same problem. vMix will load any two in any order, but not a third. Help.
It doesn't seem to be a load on the CPU. It is still running fairly low.
Windows 7 HP 6000 Dual Core 3.0 4 Gb RAM I TB HDD
Thanks...
Joined: 1/13/2010(UTC) Posts: 5,373  Location: Gold Coast, Australia Was thanked: 4799 time(s) in 1647 post(s)
The issue is the limit to the amount of bandwidth available to the USB ports. You will need to install a separate USB input card to be able to use a third camera.
Martin vMix
