Graduation titles using PowerPoint
We just finished our high school graduation live stream last night. I searched all over this forum and the web for an easy way to put 319 titles with names and pictures onto my live video. I ended up doing a remote desktop capture with a power point. Chroma key with a green background. I cropped the image down to only the area I needed. Setup a title with just the background bar and created a multi-view overlay. I can say that it worked great and the fans loved it. Also, the streaming to YouTube worked great. Thanks Vmix! YouTube link to Vmix Live Production
@ ewing453 Job well done my friend. That likely took a lot of time to set-up! The closest thing I can think of that is looking into streamlining this type of process is from 'richardgatarski' http://forums.vmix.com.a....aspx?g=posts&t=2958But I think with 319 slides, the PowerPoint set-up was probably the best way to do it. Ice
