Joined: 1/23/2015(UTC) Posts: 27 Location: Los Angeles, CA
Is there a way to use the API to move inputs to a designated input number. For example, I have an input and know the GUID but want to move it to the Number 2 position. I feel there is an API command for everything but that. Any help, or am I stuck hard coding GUIDs?
Louis
Joined: 2/24/2014(UTC) Posts: 45   Location: Maine, USA Thanks: 26 times Was thanked: 15 time(s) in 12 post(s)
Unfortunately, as far as I know this is not possible.
Can I request this be added to the next version please?
Joined: 3/7/2012(UTC) Posts: 2,688  Location: Canada Thanks: 33 times Was thanked: 513 time(s) in 481 post(s)
@ gripreality
Sounds like a great "feature request" Louis. May I suggest that you formally make it in the appropriate forum. Although the board is monitored by the vMix team, this thread is for 3rd party development and might not be noticed or reacted to as quickly as those threads that deal directly with vMix and it's features.
Thanks Ice! I will make a note on the "feature request board".
