Hello, I want to create a custom animated ticker just like TickerHD.xaml but with my image instead of the red color in the background. I tried to do that with vmix designer but I could not animate the text.
Thank you
@ elshorbagy I'm guessing here, but depending on how 'different' you want your custom ticker to be, if the major 'elements' are the same, (i.e. scrolling text), you should be able to "edit" new elements into the "TickerHD.xaml" file and save it as a new file with the vMix Title Designer. Failing that, you will likely have to develop your own animation with Microsoft Blend: http://www.microsoftvirt...ui-with-blend-jump-startsince the vMix Title Designer is a basic editor for xaml files but not an animation script capable program AFAIK. Ice
