apell
#1 Posted : Tuesday, May 26, 2015 12:31:47 PM(UTC)
apell
Good friends, I ask you a tip.
Tell me, why the audio stream is interrupted each time I open this function?
apell attached the following image(s):
vmix no sound.jpg (90kb) downloaded 0 time(s).
PFBM
#2 Posted : Tuesday, May 26, 2015 2:10:40 PM(UTC)
PFBM
hi
unclick mix with audio on preferences .
PFBM
thanks 1 user thanked PFBM for this useful post.
apell on 5/26/2015(UTC)
#3 Posted : Tuesday, May 26, 2015 4:16:12 PM(UTC)
@ apell
Have a look at this thread which is a similar issue and may help to 'illustrate' how the audio buttons work in vMix:
http://forums.vmix.com.a....aspx?g=posts&t=3539
apell
#4 Posted : Tuesday, May 26, 2015 6:26:46 PM(UTC)
apell
Thanks to your help, i think found a solution, i hope permanently!
Apell
