Jounas
#1 Posted : Saturday, May 9, 2015 3:50:27 PM(UTC)
Jounas
I'm running a project that uses several Stream Inputs, that are required to be somewhat synched to each other. We are doing the sync by adjusting streaming buffer lengths in the input settings windows. I feel that this requires too many clicks to achieve, and takes too much of valuable time when setting a show.
It would be neat to be able to view, set and adjust Stream Input buffer length just by right cliking on the input preview. Simple right click should bring a context menu, with current buffer length visible. That could be changed to some other value, and maybe confirmed with a button (with ability to cancel).
Confirming a new buffer lenght with a menu button click would be good, as readjusting buffers will cause a slight drop or glitch in the streams. With a button click I'd be able to time the re-adjustment so that it will be less distracting.
