Joined: 10/30/2013(UTC) Posts: 290 Location: The Netherlands
Thanks: 6 times Was thanked: 21 time(s) in 15 post(s)
After moving an input in a category the input number is changed and doesn't corresponding anymore with the originally API call. Whit fixed input ID's (in order of adding) that problem is solved. Input numbers that don't change after moving is also a possibility. EDIT: This is already discussed here
