rugerio
#1 Posted : Saturday, April 11, 2015 3:54:32 PM(UTC)
rugerio
I would like to.know if i can use a usb to vga device (StarTech USB32HDDVII USB 3.0 to HDMI and DVI Dual Monitor External Video Card Adapter) to progam output on vmix.
I want to use it on my macbook pro mid 2012 no retina with bootcamp and windows 8.1 pro. My mbp does not have vga or hdmi output i must output from the thunderbolt port but this does not work in bootcamp and windows os. So i want to know if i can use the mentioned device to output the program from vmix to my vga external monitor but using as main gpu the nvidia internal video card from my laptop. Is this possible?
ask
#2 Posted : Saturday, April 11, 2015 7:06:08 PM(UTC)
ask
Yes it should work.
