Joined: 1/25/2014(UTC) Posts: 50   Location: Bethel Thanks: 9 times Was thanked: 1 time(s) in 1 post(s)
Team,
I'm running several vMixHD machines along side a test version of vMix 15.
I've not been able to record or stream any audio from videos that I play from within vMix. I'm running a mixer through a usb sound card on each machine but can't get vMix to send the audio out. Using the same machine I can get audio from videos I play on YouTube, thru the browser, and also can play videos with media player and get output to the mixer. Inside of vMix I see the audio outputs playing via the visual vertical audio bar but nothing comes through the mixer.
Any help or guidance would be appreciated.
beloved
Team,
I finally tracked down the issue I was having. It required updating the realtek drivers to the Mar 15, 2015 update. All vMix versions on Win 7 & 8 are working fine. I hope this may help a few of you!
beloved
