coskel22
#1 Posted : Friday, March 27, 2015 6:30:23 AM(UTC)
coskel22
Using 14.0.0.12
After a bad Windows shutdown, vmix opens and works except for the XML based titles/scoreboards/ticker.
None of the pre-made ones will open, it hangs and gives a timeout error?
Len56
#2 Posted : Friday, March 27, 2015 10:06:19 AM(UTC)
Len56
It looks like something has become corrupt in your version so first try this:
goto C drive/ Users/ Your Name folder/ AppData/ Local/ StudioCoast_Pty_Ltd/ vMix64.exe folder/ there will be a folder of your version of vMix, open that folder and inside there is a file called (user.config) delete that file and restart vMix. What this file does is hold all the vMix preferences so you will have to reset all your preferences you made before.
If you can't see the AppData folder goto Tools, Folder Options, view tab and click on (Show hidden files, folders or drives) this will then let you see the AppData folder.
If that doesn't work goto the vMix download page and install the latest version 15.0.0.68 and see if that cures your problem.
