marius
#1 Posted : Saturday, March 21, 2015 6:06:29 AM(UTC)
marius
Dear sir,
I tested version Vmix 14 with capture card Videum Quattro Xpress - Winnov and is a problem, the image is the vertical black stripes on the screen and deinterlace enabled on each camera.
Vmix version 15 is not able deinterlace each input camera. The image is very bad without deinterlace.
YOU CAN DO THIS Vmix compatible with capture cards?
Best regards
Marius.
#2 Posted : Saturday, March 21, 2015 6:12:32 AM(UTC)
Was thanked: 4708 time(s) in 1613 post(s)
When adding the Camera input, make sure an interlaced frame rate is selected such as 50i or 59.94i
and then check the Interlaced checkbox. This will make sure the camera is deinterlaced.
marius
#3 Posted : Saturday, March 21, 2015 6:26:41 AM(UTC)
marius
i use analog input camera 720x576 pal 25p.
this is analog capture card: http://www.winnov.com/pr...m/videum-quattro-xpress/
Multi-Board Capable Yes
SMP Capable Yes, optimized for multi-processor systems
Video Sources 8
Video Capture Channels 4 independent channels, aggregate 120 frames/second, 240 fields/second
Connector Type BNC
Video NTSC or PAL
Capture Formats Motion JPEG compressed video
Uncompressed video (YUV 4:2:2, YUV 4:2:0, or RGB)
Image Size Programmable per channel
32×24 640×480 (NTSC)
32×24 to 704×576 (PAL)
On-board Video Processor Brightness, contrast, hue, saturation
Video Capture Performance Up to full resolution, full frame rate per channel
Digital I/Os 8 Port TTL I/O with interrupt/event signaling
Display Full screen with DirectDraw™ capable graphic card
Text and Graphics Overlay Up to full resolution, full frame rate per channel
Watchdog Function Yes, programmable with automatic failure log
De-Interlacing Yes
Elastic Frame Buffer Yes
Video Loss Detection Yes
Video Signal Termination Yes
Video Input 4 BNC (4 Composite or 2 S-video)
Audio Formats Up to 48 KHz 16-bit
AV Synchronization Fully synchronized to system multimedia clock
Audio Output 2x 1/4″ TRS-phono jacks (balanced stereo)
Audio Input Audio-In 1 : 2x combo XLR and 1/4″ TRS phono jacks (balanced stereo)
Audio-In 2 : 2x 1/4″ TRS-phono jacks (balanced stereo)
Audio-Out : 2x 1/4″ TRS-phono jacks (balanced stereo)
CPU Performance AMD and Intel CPU support, 1 GHz or higher
System Memory 512 MB
Operating System Microsoft Windows 2000, XP (x86 and x64), Vista (x86 and x64),
7 (x86 and x64), 2003 (x86 and x64), 2008 (x86 and x64),
2008 R2 (x64)
PCI Express One x1 PCI Express slot (can be used in x4, x8, x16 PCI Express slots)
Dimensions LxH 6.78″ x 4.4″
172mm x 112mm (PCB size w/out bracket)
Software Applications Windows Media™ Encoder 9, Windows Messenger, Microsoft Expression™ Encoder, Flash™ 2 Encoder SDK (Videum software development kit included)
#4 Posted : Saturday, March 21, 2015 7:09:26 AM(UTC)
Try setting the frame to 50i in vMix instead of 25p
marius
#5 Posted : Saturday, March 21, 2015 7:21:29 AM(UTC)
marius
is bad. please look the link :
#6 Posted : Saturday, March 21, 2015 7:32:08 AM(UTC)
Are you referring to the white lines in the video?
These are analog interference and can be caused by the cables, the camera or the card, but are not something vMix can fix.
marius
#7 Posted : Saturday, March 21, 2015 7:38:15 AM(UTC)
marius
IN APPLICATION VIDEUM OR WINNOV , These lines not seen under the same conditions.LINES APPEAR IN APPLICATION ONLY VMIX.
#8 Posted : Saturday, March 21, 2015 8:13:14 AM(UTC)
Could you provide a screenshot of the Add Input -> Camera window in vMix
and also a screenshot of the camera within vMix showing the lines.
It may be that the graphics card in the computer is causing interference as vMix relies heavily on the graphics card.
marius
#9 Posted : Saturday, March 21, 2015 8:39:29 AM(UTC)
marius
I can not attach video capture
Handles attachments
vmixstorage - 20 March 2015 - 03-16-39 PM.wmv (1,420kb) downloaded 5 time(s).
marius attached the following image(s):
capture 1.png (1,311kb) downloaded 7 time(s).
#10 Posted : Saturday, March 21, 2015 9:20:47 AM(UTC)
Thanks, the picture in that screenshot looks ok.
What are the system specs of the computer such as CPU, graphics card etc?
marius
#11 Posted : Saturday, March 21, 2015 9:21:43 AM(UTC)
marius
we did capture video
system dell
i7 Processor Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz, 3401 Mhz, 4 Core(s), 8 Logical Processor(s)
8Gb ram
160 GB SSD INTEL
GRAPHIC CARD NVIDIA GFORCE GT730
OS Name Microsoft Windows 7 Professional
Version 6.1.7601 Service Pack 1 Build 7601
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name PLAYOUT-PC
System Manufacturer Dell Inc.
System Model OptiPlex 790
System Type x64-based PC
BIOS Version/Date Dell Inc. A16, 8/21/2012
SMBIOS Version 2.6
Windows Directory C:\Windows
System Directory C:\Windows\system32
Boot Device \Device\HarddiskVolume1
Locale United States
Hardware Abstraction Layer Version = "6.1.7601.17514"
User Name PLAYOUT-PC\PLAYOUT
Time Zone GTB Standard Time
Installed Physical Memory (RAM) 8.00 GB
Total Physical Memory 7.96 GB
Available Physical Memory 5.61 GB
Total Virtual Memory 15.9 GB
Available Virtual Memory 13.1 GB
Page File Space 7.96 GB
Page File C:\pagefile.sys
File Attachment(s):
vmixstorage - 20 March 2015 - 03-16-39 PM.wmv (1,420kb) downloaded 2 time(s).
#12 Posted : Saturday, March 21, 2015 9:56:54 AM(UTC)
It looks like the interference is caused by the card when adding multiple inputs.
I would suggest reporting this issue to Winnov as it does not appear to be related to vMix.
marius
#13 Posted : Saturday, March 21, 2015 10:08:33 AM(UTC)
marius
ok. the future can add the option to deinterlace it was in version vimix 14.
thank you for support
#14 Posted : Saturday, March 21, 2015 10:32:00 AM(UTC)
Hi Marius,
The inputs are already being deinterlaced, this is the same as vMix 14 but has been labelled differently.
(50i instead of deinterlace box)
The interference seen on the video is not interlacing.
