Hi, I would like to ask if the graphic card NVIDIA GeForce 210 is compatible? I'm having some problems with the streaming and the vMix.
@ Faber
The 210 is a lower end card and you may run into performance issues depending on what it is you are trying to do with it and vMix. Any of the NVidia GeForce x50 (or better) cards with 1GB (or more) of memory are recommended for use with vMix. Streaming issues may have more to do with your processor since that is typically where the encoding is done for that. What are the specs of your system and what exactly are the "issues" you are having?
Ice, My stream is freezing the image. My users say that the video freezes. I'm using a I5, 4Gb RAM, vMix 15.0.0.66 with NVIDIA GeForce 210 and the Dark Crystal HD Capture Pro - Avermedia.
Faber
I often use a low end Core i3 with internal Intel GPU for recording and streaming in 720p without any problems.
@ Faber
Is the stream 'freezing' or is vMix 'freezing'? In other words, do you notice the issue on your computer, or just the end users (viewers)? It sounds like it might be more related to your internet connection and/or bandwidth availability for your desired stream. You will have to provide a few more details with respect to your set-up and streaming configuration to narrow down the 'root' cause of your issue.
