snedecor
#1 Posted : Thursday, March 5, 2015 9:27:51 PM(UTC)
snedecor
I want to auto-start the desktop capture, but I don't want it to clutter the main screen, but be minimized to the system notification area and ready to do it's work in the background.
When I put it in the start menu, it runs, but ends up open on the screen of the presentation computer, and the technicians running the computer have sometimes closed it, or wonder what it is.
Can you have it to obey a /minimize flag if invoked that way from the start menu, or have a .ini option, or something similar? I would also like it to not have a taskbar entry, but to take itself to the system notification bar. That way, it does its work silent and efficiently!
Thanks!
