jorisdv
#1 Posted : Friday, November 20, 2026 7:49:30 AM(UTC)
jorisdv
Hi
Our Mixing and Replay are separate workstations and operated by dedicated operators.
Playing back an event from the Replay to the Mixing station is no problem (e.g. SDI or OMT).
The challenge is to know on the mixing station how long the event/replay lasts or will about to take.
Is there a way how to get this information available?
Ideally this would be similar to playing a video which shows the length of the video and time to end.
Kayo33
#2 Posted : Friday, November 20, 2026 8:42:18 AM(UTC)
Kayo33
Was thanked: 18 time(s) in 14 post(s)
Capture the full-screen output of the multiview replay or the instant replay controller screen—using a GPU output splitter—and send it to a second monitor at the production/control station (alternatively, you could daisy-chain two DisplayPort monitors).
Another option is to capture the replay PC via NDI, then crop and zoom to isolate the specific area you want and display it within the multiview.
#3 Posted : Friday, November 20, 2026 9:26:27 AM(UTC)
Originally Posted by: jorisdv Go to Quoted Post
Hi
In vMix 30 (Beta for now) the xml API gives you the total remaining play time of the selected events.
