Joined: 9/17/2013(UTC) Posts: 173  Location: Norway Thanks: 10 times Was thanked: 56 time(s) in 29 post(s)
Hi vMixers! We from Njastad.com are happy to present to you the "vMix Next Up!" plugin! This plugin allows you to notify your users about your next program, and the best part? It's all automatic! All you need to do is to schedule all your shows and the plugin goes live by itself! The plugin can be purchased here; http://shop.njastad.com/...roduct&product_id=60And here is a demonstration video!Happy mixing Sondre Njåstad Developer @ shop.njastad.com
Joined: 6/29/2011(UTC) Posts: 315   Location: Florida Thanks: 6 times Was thanked: 34 time(s) in 33 post(s)
Hey Thremir, Nice stuff! Hey what I need is a more complete scheduling module. There is a scheduling app for vMix which is in alpha status and very unlikely to change anytime soon. I believe the code is free to download and expand on. I need a scheduler that not only allows typical video and graphics control with in and out points but also when to start streaming and stop streaming Scheduling overlays such as your title pack, This would be a great plugin for vMix !! Thanks for all your efforts Ed
Joined: 1/25/2014(UTC) Posts: 50   Location: Bethel Thanks: 9 times Was thanked: 1 time(s) in 1 post(s)
Yea! Again, many thanks for your efforts!!! I'd like to second the above request! An excellent opportunity awaits a team of programmers with the moxey to take vMix Sceduler to the next level. I'm sure you've seen all the posts for it in the 3rd party developement forum section, if not check it out! Here's the link to the vMix Scheduler software: http://www.weir3d.de/film/vMixSchedulerTake note of the source code at the bottom of the page! An unbelievable opportunity awaits you there! Beloved
