Joined: 4/23/2017(UTC) Posts: 1,495  Location: Germany Thanks: 3 times Was thanked: 199 time(s) in 179 post(s)
I have written a small software that provides a browser based real time spectrum analyzer. It has different views. 1/3 octave, FFT and Waterfall diagram. The ingest is done via USB, or a VST3 plugin. So you should be able to use it almost everywhere. I'm also working of ASIO integration. I tried native Dante but that requires a token from Audinate that I don't have and not going that route. DVS in WDM mode works. If anyone is interested let me know.
The project has finalized. A browser RTA that can ingest from USB, ASIO, system sounds (MME, Windows Direct Sound, Windows WASAPI, Windows WDM-KS) including loopback and a VST3 plugin that can be run by any app that supports it.
Dante (in AES67) and Asio added as input as well. Plus a few bug fixes and code hardening. PM me if there is interest.
Joined: 12/14/2018(UTC) Posts: 163   Location: Clermont-Ferrand Thanks: 38 times Was thanked: 10 time(s) in 9 post(s)
Hello Mavik, I'd be curious to give it a try.
