JosefinaF
#1 Posted : Monday, July 20, 2026 10:22:53 PM(UTC)
JosefinaF
vMix closed unexpectedly twice, without any warnings, and when I looked at the logs it says
Error disabling WindowsUpdate: vMix.vMixServiceException: vMix Service Not Ready
Any ideas on how to solve this issue?
Thanks!
Luis70
#2 Posted : Monday, July 20, 2026 10:26:12 PM(UTC)
Luis70
Grenada
I would disable Windows updates before launching vMix, or resolve crashing by performing an update of NVIDIA drivers
#3 Posted : Monday, July 20, 2026 11:28:15 PM(UTC)
Was thanked: 4735 time(s) in 1624 post(s)
Please note this error is not at all related to any vMix or any other app closing issues.
It just means that the feature in vMix to temporarily disable Windows Updates while running was not active.
As for why vMix is closing in your code, as I note you have already contacted vMix support, it seems the issue could be due to the faulty Intel 14th gen CPUs, such as the 14900K.
You can run the https://www.intel.com/co...sor-diagnostic-tool.html to see if this is the case.
JosefinaF
#4 Posted : Friday, July 24, 2026 2:08:09 PM(UTC)
JosefinaF
Still no luck, I've updated all the drivers and vMix crashes randomly at different hours, I don' know what else to do, it says that there is an error on system32 ntdll.dll
Applehead
#5 Posted : Friday, August 7, 2026 6:23:09 AM(UTC)
Applehead
Philippines
I also experiencing this kind of error. Windows Logs shows that there is an error on ntdll.dll. I tried updating my GPU Drivers, still no luck.
MarcoM
#6 Posted : Tuesday, August 18, 2026 12:17:21 AM(UTC)
MarcoM
Netherlands
vMix disables the Windows Update functionality while it's running. You don't want your machine to start installing updates during a live broadcast.
As this probably requires admin privileges it can't be performed by vMix itself as it most likely not runs under admin privileges. Therefore when vMix is installed it also installs a service called "vMixService". This runs under the Local System account and thus has admin privileges. The error probably means something is wrong with this service. It should auto start when your machine boots up.
To get to the services press the Windows key and type "services". Open the first item and search for "vMixService" in the list. Double click it to open it's settings and status. You can also start it there and when necessary change it's startup type to Automatic if it's not set to that yet.
