MegaJos
#1 Posted : Sunday, February 22, 2015 7:04:32 PM(UTC)
MegaJos
I just realized something. The video delay function is quite useless when just being able to record in 25 fps. Slowing that down to just 75% makes the movement very slugish. To make a good replay in hockey you need 120 fps.
That wouldn't be too much to ask, would it? That's one of my last needs for vMix.
Tip: A budget camera for that is the Panasonic HC-V750.
#2 Posted : Sunday, February 22, 2015 10:22:51 PM(UTC)
No cameras currently on the market can output higher than 60p over HDMI or SDI as there is no standard for these higher frame rates.
They only record high frame rates to file.
You can use 60p inputs so playing back at 50% is still 30p, but that is the best that is available.
