I will to go livestream
My question is:
Can I use the roxio game capture hd pro with V Mix
Joined: 9/17/2013(UTC) Posts: 173  Location: Norway Thanks: 10 times Was thanked: 56 time(s) in 29 post(s)
Pikmar wrote:I will to go livestream
My question is:
Can I use the roxio game capture hd pro with V Mix Short answer; No. There is however some ways of adding it into xSplit and running Virtual Webcam output into vMix, but it's not recommended (or running a local RTMP server with the included software). As of today I think xSplit and the software that comes with the device supports it, not a limitation within vMix really. Cheers, Håvard
Thanks: 3 times Was thanked: 5 time(s) in 4 post(s)
Download the free trial and see what happends?
