Regarding the operating configuration solution for the 5375x1735 LED screen in the TV studio
We have a 5375x1735-pixel LED screen that will be installed in our new TV studio. Of course, this is a horizontal screen, and for its technical operation, I’m planning to use a custom PC configuration and the VMix software. Media servers are very expensive, and we’ll be using the LED screen for simple applications—meaning we won’t be playing videos across multiple layers. The LED engine model is NOVASTAR VX16S.
It has 1x HDMI 4K, 2x SDI HD inputs, and 4x SL-DVI inputs.
Here’s my solution—do you think I can play content smoothly without any issues for a simple LED setup?
My PC configuration:
Intel Core Ultra 9 285K
NVIDIA GeForce RTX 5080
ASUS ProArt Z890-CREATOR WIFI
64GB (2x32) DDR5 8000MHz CL34
1TB Samsung 990 Pro Gen4 (OS and vMix software)
4TB Crucial T705 Gen5 NVMe (14,500 MB/s read)
Corsair iCUE Link H170i (420mm) LCD
1350W Thermaltake Toughpower iRGB PLUS (ATX 3.1)
Lian Li O11 Dynamic EVO XL (or Corsair 7000D)
6x Noctua or Corsair AF120 Elite.[/b][/b]
I’ll also be installing a Blackmagic 8K Pro G2 capture card. My plan is as follows:
From SDI Input 2: 1080 50i to Atem Live input.
SDI2: 1080 25p out.(external 2)
SDI3: 1080 25p out.(external 3)
HDMI Out: 4096x2160 25p output. (external 4)
1x BLACKMAGIC 8K PRO G2 CAPTURE CARD
I will set the center portion of a 5375x1735-pixel LED screen to 4K. I also plan to use two 1080p25 outputs to send the remaining right and left sections of the screen from V-Mix’s external outputs 2 and 3 as separate 1080p25 cropped outputs.
I can also use the AUX signal from the video mixer as an input via the SDI 2 port and display it as an overlay instead of the 4K feed in the center. Do you think this PC configuration and solution will work? I’ve given a lot of thought to the PC configuration in particular.
(235kb) downloaded 23 time(s).
