TL68
#1 Posted : Wednesday, April 29, 2026 9:56:09 PM(UTC)
TL68
Sweden
Hi!
On a title input you can right click and choose "reload" which most often solves problems with the title not updating from datasource and also apply changes made in the GTtitle zip file.
But there is no "reload" shortcut or api function as far as i know.
There is however the Reset input shortcut and api function. If I run this on a GT title it seems to do the same stuff as reloading it whith a right click in the input panel.
But is this actually doing the same stuff under the hood when used on a title input, or are there differences I need to be aware of?
