knbPixels
#1 Posted : Tuesday, April 21, 2026 6:00:19 AM(UTC)
knbPixels
The ability to animate a layer of an input would be fantastic. In understand you can merge, but that requires creating additional inputs (not great when you already have a huge show file). I also know you can animate using titles, but I'm talking about things that aren't titles like camera inputs on a multiview layer.
#2 Posted : Wednesday, April 22, 2026 1:05:10 AM(UTC)
@knbPixels
If I understand you correctly, some of that is already possible with the "SwapLayerAnimated" and "SetLayerAnimated" Shortcuts as explained towards the end of this video:
?si=sb_n-C6uRjbg0cOG
henrydavid
#3 Posted : Thursday, April 23, 2026 5:57:18 PM(UTC)
henrydavid
I totally get what you mean-merging inputs or using titles feels more like a workaround than a real solution, especially in a complex project. Being able to animate layers directly within an input would make things much more efficient and flexible. It would save time, reduce clutter in large show files, and give better control over elements like multiview camera feeds. Hopefully this is something the developers consider adding in future updates.
knbPixels
#4 Posted : Monday, April 27, 2026 5:28:18 AM(UTC)
knbPixels
Originally Posted by: IceStream Go to Quoted Post
@knbPixels
Yeah that kind of makes something happen in a very basic sense. The issue I have is that you have to dedicate two layers for each one object you want to move...the starting position and the ending position. We only have 10 layers to work with, so you run out of layers fast. You could do some embedding and make a layout just to hold the cameras, and then put that on a layer of your final input you're building, but that sort of nested approach is convoluted and messy...makes making changes later a PITA. Really the feature I would want would rely on something similar to after effects or something, where you define starting position, ending position and speed somehow, and a shortcut to make it go.
