Hello everyone,
I’m currently working in a solo production setup using vMix (interviews), as my operator had an accident and I promised not to replace him until he returns. So for now, I’m running everything myself — and the show must go on.
**Context:**
I’m using three monitors:
* Monitor 1 → vMix interface (control)
* Monitor 2 → main working monitor (program output)
* Monitor 3 → Preview
Since I operate everything alone, I need a **quick visual confirmation that each microphone is active**, without constantly watching the Audio Mixer window.
**Goal:**
I would like to display a **visual audio level indicator (VU meter)** on Monitor 2, together with the program output, but **strictly for monitoring purposes**, without it appearing in recording or live output.
**What I’ve tried so far:**
* Stream Deck → not suitable for real-time audio monitoring
* Desktop Capture → works, but not very clean
* Overlay → works, but appears in recording (not acceptable)
**Current approach:**
I’m experimenting with a scripting-based solution, reading audio levels from the vMix XML (master L/R) and converting them into a visual indicator, which I include in a separate layout and send to an external monitor.
The idea is to have on Monitor 2:
* the program output
* * a clear visual confirmation that audio is present
without affecting the final output.
**Questions:**
1. Is there a simpler or more native way in vMix to display audio levels only on a monitoring screen?
2. Is it possible to generate a video output that includes audio meters, but only for monitoring purposes?
3. Has anyone implemented a similar “confidence monitor” setup (program + audio confirmation in a single view)?
I also found this thread discussing overlay on output, which is somewhat related to my use case:
https://forums.vmix.com/...-Overlay-on-Output-Input---
Any suggestions or ideas would be greatly appreciated.
Thank you!
