Data Source values on Streamdeck
A while ago I was able to show values, which i did have selected in a data source (excel) on my streamdeck using companion. This was by reading the values from a graphic, which was connected to the data source. I think this was with an older version from Companion (2.2?).
In the newer Companion version I can't find a way how to do it. I would like to show a number from my data source on my streamdeck. This way i can control i have selected the right line on my streamdeck before giving a graphic.
Thanks for the help! Hylke
Thanks: 64 times Was thanked: 158 time(s) in 142 post(s)
Thanks for the help! Hylke You can insert it as a variable in the button text string field. You have to enable the title variables for vMix on the Connections page first, then you can find the correct variable in the Variables section.
