3579865
#1 Posted : Monday, February 16, 2026 11:04:21 AM(UTC)
3579865
How to manipulate the position values for an input's layer? I'd like to rotate a MIDI knob, and zoom an input, while also calculating new positions for a few other layers on that input (so they get smaller and move to the sides, still visible, not behind the main layer now larger). I've got a script basically working, but can't seem to get the MIDI knob value into it.
Is there a better way to approach this?
If not, how to execute a script and pass in a MIDI rotary knob value?
So far I've configured a shortcut so that rotating the MIDI device knob sets DynamicValue1. I can see the value changing by refreshing http://127.0.0.1:8088/api, so I know that part is working.
How do I also simultaneously kick off a script (with every click of the knob) to use that value?
Appreciate any guidance.
mavik
#2 Posted : Monday, February 16, 2026 7:34:51 PM(UTC)
mavik
Take a look at https://www.vmix.com/hel...utFunctionReference.html
You can manipulate the layer position with SetLayer for instance.
3579865
#3 Posted : Wednesday, February 18, 2026 2:10:10 AM(UTC)
3579865
Thanks for the pointer. Those function are working for me.
My current obstacle is that changing the rotary knob does not execute my script with the knob value.
