eashackelford
#1 Posted : Thursday, January 29, 2026 5:35:33 AM(UTC)
eashackelford
This is a paid position - heavy preference if you are in the Calgary area.
The Schedule:
Late Feb – April: Remote prep/consulting.
April 25 – 30: On-site build, rigging, and tech rehearsals.
May 1 – May 5: Live shoot days.
Technical Requirements:
Deep knowledge of triggers, data sources, and SRT/NDI integration.
Experience preferred with PokerGFX, VideoBuzz, or custom XML/JSON data sources for live poker overlays (hole cards, pot odds, etc.).
Hardware: Ability to spec/build a redundant 12-input SDI workflow (DeckLink/Magewell).
Comms: Experience with Unity, Clear-Com, or vMix Call for communication.
Best is emailing me at eric@thedigitalpresence.com
