SnowTVUT
#1 Posted : Friday, January 16, 2026 7:31:27 AM(UTC)
SnowTVUT
I know that my use case is pretty unique so I'm not completely expecting an answer here but I'm running vMix on my M4 Max Macbook Pro via Parallels.
I have a BlackMagic ATEM Mini Pro ISO as my capture card, all of my cameras are run into it as a switcher then I have a single USB-C cable running from that to my computer. I use this for sports broadcasting so I would really like to run replays. The goal is to have the final version in 30 fps but I would like to be able to slow down my replays so if there's any way to record the replays at 60 fps and replay in 30, that would be ideal.
I keep trying to get it running but each time I hit record, it gives me a "Replay Tick" error. I can provide the log if needed. HELP!!
