uv-mapping artifacts when transparency is involved
Joined: 5/9/2021(UTC) Posts: 17  Location: Thessaloniki Thanks: 2 times
I have the following issue. When a layer in a virtual set has a uv-map and that map is pointing to an image (or video) that includes transparency, then I see a line at the bottom and right of the bounding box. Is this a known issue? Is it possible to solve that p.s I have moved the image around on a black background so it's more evident.  issue.png (89kb) downloaded 12 time(s).
