Joined: 12/4/2019(UTC) Posts: 25  Was thanked: 1 time(s) in 1 post(s)
I have setup with 5 cameras on hockey game. During the gameplay i make some clips in Replay controller for future Higlights production. All my cameras sends 108050i signal, means "interlaced", so all check boxes are checked in camera settings. During the export I select AVI codec. I belive that all cameras in resulting export clip should be deinterlaced, but only first camera is deinterlaced and the oter agles not. You can dowlad clip here (1.37Gb) 1_MYU-Sputnik_28_12 - 2 - Camera12345 moment - - - - [13-04-35] [13-04-55].aviI have the latest version of vMix 29.041 To solve this issue I forced to get all my clips over Adobe Media Encoder with manually checked "interpreter footage as interlaced" How to fix this issue in future?
Try exporting in MP4 High quality. It should be without interlacing.
Originally Posted by: Pavel  Try exporting in MP4 High quality. It should be without interlacing. No, AVI encoding much faster than MP4. I have lack of time for export.
