Instant Replay
Alternating Stinger Transitions
Joined: 8/3/2015(UTC) Posts: 325 Location: Chicago, IL
It’s been many years since I have been logged in but I am back in the hot seat with vMix and I am loving the updates on Version 29.
I would like to be able to alternate between 2 stinger transitions (1 & 2) between each instant replay launch. I am streaming Brazilian Jiu-Jitsu matches and at the end of each match we will be displaying the highlights of each match with instant replay on screen at the venue and online via YouTube stream.
Instant replay will launch only once for each match and I am wondering if vmix can switch between 1 & 2 after each match. I know I can program 2 shortcuts and press one of 2 buttons to launch each independently, but I am a solo operator and try to make as much automatic behind the scenes as possible. We have 2 sponsors for replay and want to give them both equal air time.
It’s good to be back in the video production world. Hopefully there are some ideas to accomplish this task. Thanks in advance.
Joined: 5/14/2013(UTC) Posts: 155  Location: uk Thanks: 2 times Was thanked: 28 time(s) in 24 post(s)
If using a stream deck and companion you could have a two step button that just fires a different one on each step
Instant Replay
