TFMG
#1 Posted : Tuesday, December 16, 2025 9:43:43 AM(UTC)
TFMG
When exporting events from the Replay system, the colour correction options for the source input are not applied. I understand this may be due to it being more system intensive to apply the colour correction options during the render process, but it would significantly decrease the amount of time spent on post-production work before getting events out on Social Media, or completely eliminate re-compression of the footage by importing it into a linear editor to apply colour correction there. Any additional load on exporting clips with colour correction applied should be made optional with a checkbox on the Export window in order to give users the choice to render exported clips with or without colour correction applied.
The inclusion of this feature would also benefit the use case of exporting ISO recordings from the Replay system for archival purposes, especially as you cannot use Multicorder (which I acknowledge also doesn't apply the colour correction) while using those inputs as a Replay source input.
Implementing this feature would also save excess system resources being used in the workaround of routing an input through an Output in order to apply the colour correction settings into replay - which is also limited to 3 Aux Outputs plus the Program Output.
The attention to the Replay feature in vMix 29 indicates plans for future development in this area, so it would be the perfect time to implement these changes to allow for more streamlined workflows around the Export function of the Replay feature.
Thanks in advance for your consideration of this request.
- Michael Smith
Thought Fox Media Group
