Systems
Help with Reference System
Joined: 9/30/2025(UTC) Posts: 4  Location: California Thanks: 3 times
Hi. Where would a computer with the specs below fall on the vMix reference systems?
Motherboard: Gigabyte B860I AORUS PRO ICE
CPU: Intel Core Ultra 7 265K 3.9GHz 20 Core 30MB 125W
GPU: NVIDIA GeForce RTX 5080 16GB In Stock
RAM: 64GB DDR5-5600 (2x32GB)
Storage: 1TB NVMe PCIe Gen4 M.2 SSD
Thanks in advance for any help you can provide
Joined: 10/20/2023(UTC) Posts: 162  Thanks: 3 times Was thanked: 18 time(s) in 14 post(s)
Ruby system with one additional NVENC GPU capture cards only via Thunderbolt 4 / pcie enclosure and one less M.2 slot managed by the CPU
or upgrade MB + CPU (Z890 + ultra 9 285K) and downgrade GPU (5070 ti) for Topaz system
Thanks for the response. I was hoping this would allow for 4k, but i guess ill just need to build it, unless you know of any off the shelf obtanium solutions
To build a Obtainium system, opt instead for the MB ASRock WS790 (better distribution of PCIe CPU lanes for 4K capture cards in PCIe x8, and more M2 slots)
Systems
