stream2: Stream has disconnected
Joined: 12/18/2018(UTC) Posts: 1  Location: Westminster
Subject: stream2: Stream has disconnected Body: I copy only one URL but it showed 2 URL
Stream2: Stream has disconnected. Check the stream settings (such as URL and Key) are correct and try again. rtmp://a.rmp.youtube.com/live2/rtmp://a.rmp.youtube.com/live2.
FFMPEG2.Exited Streaming Stream #0:1: Audio: pcm_s16le, 48000 Hz, 2 channels, s16, 1536 kb/s rtmp://a.rtmp.youtube.com/live2/rtmps://a.rtmps.youtube.com/live2: Input/output error ffmpeg started on 2025-12-15 at 06:52:19 Report written to "C:\ProgramData\vMix\streaming\streaming2 20251215-065219.log" ffmpeg version 2.8.git Copyright (c) 2000-2015 the FFmpeg developers built with gcc 4.8.1 (rev2, Built by MinGW-W64 project) configuration: --enable-gpl --enable-version3 --enable-libx264 --enable-zlib --enable-libfaac --enable-nonfree --cpu=i686 --enable-nvenc libavutil 55. 2.100 / 55. 2.100 libavcodec 57. 3.100 / 57. 3.100 libavformat 57. 2.100 / 57. 2.100 libavdevice 57. 0.100 / 57. 0.100 libavfilter 6. 9.100 / 6. 9.100 libswscale 4. 0.100 / 4. 0.100 libswresample 2. 0.100 / 2. 0.100 libpostproc 54. 0.100 / 54. 0.100 Guessed Channel Layout for Input Stream #0.1 : stereo Input #0, dshow, from 'video=vMix Video YV12:audio=vMix Audio': Duration: N/A, start: 31732.025000, bitrate: 1536 kb/s Stream #0:0: Video: rawvideo (YV12 / 0x32315659), yuv420p, 1280x720, 29.97 tbr, 10000k tbn, 29.97 tbc Stream #0:1: Audio: pcm_s16le, 48000 Hz, 2 channels, s16, 1536 kb/s [tcp @ 05e2a980] TCP Buffer has been set to 6571008 bytes rtmp://a.rtmp.youtube.com/live2/rtmps://a.rtmps.youtube.com/live2: Input/output error IsRead: False IsReply: False
Joined: 8/2/2013(UTC) Posts: 1,100   Location: Fairhope, Alabama USA Thanks: 592 times Was thanked: 204 time(s) in 170 post(s)
Looks like you may have accidentally entered incomplete information in Streamer Settings for the second stream.
- Tom
