BroadKast
#1 Posted : Friday, December 5, 2025 4:01:46 AM(UTC)
BroadKast
First of all, vMix Rocks!
So - this has happened (sporadically) several times now.
I load a previously used bundle and start a broadcast.
I click on a title input (Stripey) as an overlay and the overlay shows in the preview window instead of the live feed. Same title worked perfectly when the bundle was used previously.
Once it is there, I can't get rid of it. Clicking the Overlay button simply blanks it and it instantly re-appears in the preview window.
In order to fix the issue, I need to delete that input and re-create it, at which time it works normally.
Copying it by creating a virtual input: No change; the virtual input behaves the same way.
BTW I've only seen this while the vMix computer is remote from me in a Splashtop session, but that's my usual scenario, and that doesn't mean it won't happen when working directly on the vMix computer (but I'm not sure!).
And usually, other title inputs that were in the bundle continue to work properly.
vMix 4K - latest version 29.0.0.40, Windows 10 Pro; and has happened with some previous versions as well.
Any ideas?
