BBCDaveF
#1 Posted : Friday, November 21, 2025 5:54:34 AM(UTC)
BBCDaveF
We are trialling vMix in an environment where not every operator will be a vMix expert. Luckily, we can use a high degree of automation via control surfaces (Stream Decks) and Shortcuts and Actuators. This means the operators are far less likely to break things, and this is important to us.
However, there is very limited support for vMixCall inputs in either Shortcuts or scripting.
We'd like new Shortcut functions to do the following:
  • Trigger vMix to generate a new caller PIN for an input (as in what you do by going to Change in that input)
  • Copy the PIN for an input onto the system clipboard
  • Copy the short link for an input onto the system clipboard
Thanks.
