LUT in Video Sets output. Limitation or Bug?
Joined: 5/9/2021(UTC) Posts: 17  Location: Thessaloniki Thanks: 2 times
If you have a video set and add a LUT to the effects, it will not be applied to the set's output. I tried creating a virtual input from the set, but this has the same behavior
The only "solution" is applying the LUT to every one of the layers, which is a lot of work if you need to change something.
Am I missing something? Is this a known limitation or a bug?
Thank you in advance.
