Blurry Multiview When Master Resolution is 1080p, Need 4K Multiview with 1080p Stream
Joined: 10/21/2022(UTC) Posts: 24   Location: ankara Thanks: 16 times Was thanked: 4 time(s) in 3 post(s)
Hello everyone,
I'm currently streaming at 1080p60 but I'm encountering a frustrating issue with my Multiview display quality.
When I set the Master Output Size in vMix settings to 1080p (1920x1080) to save on system resources, the Multiview preview window becomes noticeably blurry/soft, especially for the smaller input previews.
To fix the blurriness, I temporarily changed the Master Output Size to 4K (3840x2160) (as seen in my config file snippet), which makes the Multiview perfectly sharp. However, this high Master Resolution causes my PC to struggle significantly, even though I'm only streaming out at 1080p.
My Goal: I want to keep the main production resolution (and my Multiview) at a higher quality (ideally 4K) for sharp monitoring, but ensure the Stream Output and Recording are downscaled to 1080p60 to maintain system performance.
Is there a way to:
Set the Multiview Resolution independently to 4K?
Use a specific External Output (Output 2/3/4) for a high-quality Multiview while keeping the Master Output Size at 1080p?
Any advice on optimizing this setup to reduce the load on my PC while maintaining a sharp Multiview would be greatly appreciated!
Thank you!
