Kayo33
#1 Posted : Monday, October 27, 2025 9:19:48 PM(UTC)
Kayo33
Was thanked: 18 time(s) in 14 post(s)
We often use dedicated vMix machines for replay
with 6 inputs + 2 external outputs (via 2 x DeckLink Duo 2) that feed into the main vMix machine.
Currently, we use 2 converters on the outputs to send the signal to a monitor + the main vMix machine.
but electrical outlets are a rare commodity.
Therefore, it would be great to have an additional fullscreen output and to be able to customize the replay multiview (to only show the inputs and remove replays A and B).
Example workflow:
Screen 1 = Instant Replay panel
Screen 2 (Fullscreen 1) = Replay Multiview 2 x 3 inputs
Screen 3 (Fullscreen 2) = Replay A
Screen 4 (Fullscreen 3) = Replay B
If possible, increase the replay capacity to 9 inputs to have a 3 x 3 multiview.
thanks 4 users thanked Kayo33 for this useful post.
samirbridi on 10/28/2025(UTC), cgroom on 10/28/2025(UTC), James Novalson on 10/28/2025(UTC), snapoid on 2/20/2026(UTC)
James Novalson
#2 Posted : Tuesday, October 28, 2025 10:00:33 PM(UTC)
James Novalson
Indonesia
I thought so too, as my production needs require multiple outputs for each image.
And I think that's possible because the GPU port produces 4 outputs.
And I hope this port can also support dual GPU configurations or utilize the outputs from the Thunderbolt port, resulting in 8 outputs or more.
thanks 1 user thanked James Novalson for this useful post.
