Mark Ratcliff
#1 Posted : Wednesday, October 15, 2025 5:58:02 AM(UTC)
Mark Ratcliff
Was so glad to see the onplaybacktime trigger introduced after years of wanting to transition video while leaving audio from a VT running. Was shocked however to discover that the timing of this trigger can only be set to the nearest second!. All I want to do is overlay on the beat of the music. Please add just two more digits (frames) to the timer setting. What am I missing here???
RonaldTam
#2 Posted : Friday, October 24, 2025 2:52:10 PM(UTC)
RonaldTam
I have the same problem. Only being able to set triggers to seconds is really difficult when you need to sync frames or music.
It seems that frame accuracy is not supported at the moment, but hopefully the next update will add that option. In the meantime, you can try manually adjusting the timeline to get a little more precise.
