sergiomegom
#1 Posted : Sunday, October 12, 2025 7:15:05 PM(UTC)
sergiomegom
Spain
I have been a Vmix user for several years now, and until now, I have been quite happy with the programme despite the occasional ‘scares’ it has given me.
The thing is, it had never given me any problems WHEN WORKING with clients, until today.
I had to do a SIMPLE stream, nothing complicated (we usually do football matches with six cameras), two cameras, one of them a GoPro with an SRT from an external server (castr.io) for two days.
Throughout yesterday, the stream worked without any problems (a single output, the client's Facebook page), but today, when I tried to start streaming for the second day, it kept giving me errors. I tried switching from Facebook to YouTube and got the same error. These:
Error 1:
ffmpeg started on 2025-10-12 at 09:52:34
Report written to "C:\ProgramData\vMix\streaming\streaming1 20251012-095234.log"
Command line:
"C:\\Program Files (x86)\\vMix\\streaming\\ffmpeg2.exe" -report -rtbufsize 128M -f dshow -i "video=vMix Video YV12:audio=vMix Audio" -codec:v libx264 -s:v 1920x1080 -pix_fmt:v yuv420p -threads 4 -bufsize:v 5000k -g:v 60 -preset:v veryfast -profile:v baseline -level:v 3.1 -b:v 5000k -maxrate:v 5500k -codec:a aac -b:a 128k -strict -2 -rtmp_flashver "FMLE/3.0 (compatible; vMix/27.0.0.81)" -f flv rtmp://a.rtmp.youtube.com/live2/ -codec:v libx264 -s:v 1920x1080 -pix_fmt:v yuv420p -threads 4 -bufsize:v 8000k -g:v 60 -preset:v veryfast -profile:v baseline -level:v 3.1 -b:v 8000k -maxrate:v 8800k -codec:a aac -b:a 128k -strict -2 -rtmp_flashver "FMLE/3.0 (compatible; vMix/27.0.0.81)" -f flv rtmp://a.rtmp.youtube.com/live2/
ffmpeg version 3.3.git Copyright (c) 2000-2017 the FFmpeg developers
built with gcc 4.8.1 (rev2, Built by MinGW-W64 project)
configuration: --enable-gpl --enable-version3 --enable-libx264 --enable-zlib --enable-nvenc --cpu=i686
libavutil 55. 76.100 / 55. 76.100
libavcodec 57.106.101 / 57.106.101
libavformat 57. 82.101 / 57. 82.101
libavdevice 57. 8.101 / 57. 8.101
libavfilter 6.105.100 / 6.105.100
libswscale 4. 7.103 / 4. 7.103
libswresample 2. 8.100 / 2. 8.100
libpostproc 54. 6.100 / 54. 6.100
Guessed Channel Layout for Input Stream #0.1 : stereo
Input #0, dshow, from 'video=vMix Video YV12:audio=vMix Audio':
Duration: N/A, start: 2540.214000, bitrate: 1411 kb/s
Stream #0:0: Video: rawvideo (YV12 / 0x32315659), yuv420p, 1920x1080, 29.97 fps, 29.97 tbr, 10000k tbn, 10000k tbc
Stream #0:1: Audio: pcm_s16le, 44100 Hz, stereo, s16, 1411 kb/s
[tcp @ 05e87c20] TCP Buffer has been set to 33140736 bytes
rtmp://a.rtmp.youtube.com/live2/: I/O error
Error 2:
ffmpeg started on 2025-10-12 at 10:37:10
Report written to "C:\ProgramData\vMix\streaming\streaming1 20251012-103710.log"
Command line:
"C:\\Program Files (x86)\\vMix\\streaming\\ffmpeg2.exe" -report -rtbufsize 128M -f dshow -i "video=vMix Video YV12:audio=vMix Audio" -codec:v libx264 -s:v 1920x1080 -pix_fmt:v yuv420p -threads 4 -bufsize:v 5000k -g:v 60 -preset:v veryfast -profile:v baseline -level:v 3.1 -b:v 5000k -maxrate:v 5500k -codec:a aac -b:a 128k -strict -2 -rtmp_flashver "FMLE/3.0 (compatible; vMix/28.0.0.43)" -f flv rtmps://live-api-s.facebook.com:443/rtmp/FB-10233157886664175-0-Ab1QWiajcug5VuydJekUQsj41 -codec:v libx264 -s:v 1920x1080 -pix_fmt:v yuv420p -threads 4 -bufsize:v 8000k -g:v 60 -preset:v veryfast -profile:v baseline -level:v 3.1 -b:v 8000k -maxrate:v 8800k -codec:a aac -b:a 128k -strict -2 -rtmp_flashver "FMLE/3.0 (compatible; vMix/28.0.0.43)" -f flv rtmps://live-api-s.facebook.com:443/rtmp/
Duration: N/A, start: 479.533000, bitrate: 1411 kb/s
[tcp @ 05e67f60] TCP Buffer has been set to 33140736 bytes
[rtmps @ 05e67880] Server error: Publish Rejected: Invalid URL
rtmps://live-api-s.facebook.com:443/rtmp/: Operation not permitted
I have full permission from the administrators for both Facebook and YouTube... and it must be something specific to Vmix, because when I try to stream from OBS, it sends the signal without any problems.
sergiomegom
#2 Posted : Tuesday, October 14, 2025 8:38:37 AM(UTC)
sergiomegom
Spain
For anyone who experiences something similar.
As I said, the day before the error occurred, the programme worked perfectly. Now, when I try to disable the ‘multibitrate’ for output 2 for streams (setting it to “none” or ‘custom’), I can run stream 1 without any problems.
I don't understand the logic behind this, especially since I understand that the data from stream 1 can be ‘copied’ to stream 2 if we tell it to, but they are independent, or so I thought. Well, without any reference in stream 2, it works.
