jet
#1 Posted : Friday, October 10, 2025 2:43:42 AM(UTC)
jet
Was thanked: 40 time(s) in 38 post(s)
Have an issue with vMix output thru "BMD DeckLink SDI Micro" in/out M.2 card. The connection is initalized AND AUDIO IS GOING TROUGH but there is only black on the output when External is enabled.. Input side is working (the card has 1 input and 1 output which can work simultaneously).
Had this output issue sometimes before.. and if I remember correctly it was not the BMD Micro card that time.
I switched the cables when this started to happen and got some vMix error that capture has sopped unexpected.
So where is the settings file for vMix output configuration located so I can delete it and see if the initial defaults works..?
Using vMix 28.0.0.42
Maybe this issue is related to the earlier vMix<28 bug I discovered (and was fixed in vMix 28) when virtual inputs did loose the link to the original input when camera was offline and then became online..?
jet
#2 Posted : Friday, October 10, 2025 3:35:29 AM(UTC)
jet
(updated)
jet
#3 Posted : Friday, October 10, 2025 5:24:28 PM(UTC)
jet
My bad: After a good night sleep I noticed that the output was set somehow to a blank input for External Output4 and that cused the issue..
But it seems that vMix could be still more robust with I/O:
When the error happened all BMD devices were unavailable after the error and had to restart vMix..
jet
#4 Posted : Friday, October 10, 2025 5:33:53 PM(UTC)
jet
Have noticed this fail to re-connect issue also with a Thunderbolt capable laptop which has an "OWC Thunderbolt Hub" attached to it.
And the HUB has 3 "BMD UltraStudio Recorder 3G" SDI/hdmi Thunderbolt converter attached to it.
The issue:
When the Thunderbolt cable is unplugged and re-plugged vMix does not recognize/re-connect converters until vMix is re-started..
sinc747
#5 Posted : Saturday, October 11, 2025 5:00:05 AM(UTC)
sinc747
Was thanked: 207 time(s) in 173 post(s)
Originally Posted by: jet Go to Quoted Post
The issue:
Normal operation for vMix.
- Tom
