I notised a checkbox (v14.112) in Settings/Performance for "Enable FlipEx on Fullscreen".
This feature is not documented in the Help. Any help/explanatory information is appreciated.
Joined: 3/30/2014(UTC) Posts: 224   Location: London, UK Thanks: 23 times Was thanked: 27 time(s) in 23 post(s)
richardgatarski wrote:I notised a checkbox (v14.112) in Settings/Performance for "Enable FlipEx on Fullscreen".
This feature is not documented in the Help. Any help/explanatory information is appreciated. Yes I have seen that to, what does it do? and why is it not in the help file?
Joined: 5/14/2013(UTC) Posts: 153  Location: uk Thanks: 2 times Was thanked: 27 time(s) in 23 post(s)
Joined: 8/22/2013(UTC) Posts: 92  Location: Rochester, NY Was thanked: 13 time(s) in 9 post(s)
Just thought I'd throw out there that I noticed an issue with DWM.exe on my setup.
I have about 100 inputs, and I noticed when I was scrolling through them, DWM.exe cpu usage would spike and all my windows would become unresponsive for about 5 seconds. I eventually unticked the Enable FlipEX on inputs and that seemed to fix the problem. I have a brand new GeForce 980 Ti, so I don't know why I was having the issue.
-Brian
