Beloved
#1 Posted : Sunday, February 8, 2015 12:11:24 PM(UTC)
Beloved
I've been looking for a way to stream to two different types of servers. I'd like to stream the audio & video to a Livestream Server account, using Livestream Producer currently for this, and an Audio only stream to an IceCast2 server at the same time. I've not seen any documentation for streaming an audio only feed.
Is this feature possible in vMix HD or is there another way to capture the live audio and send to the IceCast2 server, perhaps using only 1 external output stream, but have it picked up by an external program like Livestream Producer does?
Thank You for Your Support and Comments!
Shabbat Shalom!
tcb
Jim_C
#2 Posted : Sunday, February 8, 2015 1:22:58 PM(UTC)
Jim_C
I believe you should be able to open an instance of Flash Media Encoder Live and just check the audio box. Use it to stream the audio to IceCast2 with only one external running while sending A&V with Producer.
-Jim
