Feature Requests
Assigning inputs to Stingers
Joined: 9/1/2015(UTC) Posts: 128  Location: Ecuador Thanks: 2 times Was thanked: 16 time(s) in 12 post(s)
It's possible they'll add the ability to assign an input as a stinger, both to shortcuts and in the API.
That is, being able to assign Input1 to use with stinger1.
It would help to quickly change which one to use; there are four, but they aren't enough if you're running multiple continuous events with different themes. They're not only used as transitions but also as background images (LED screens). It's a very good way to open or close them given the movement that can be achieved with GTZIP graphic transitions.
Also, the vmix XML (http://localhost:8088/api) should include the values for which input each stinger is assigned, allowing you to read the data and execute tasks.
Originally Posted by: JAIRODJ  there are four, but they aren't enough if you're running multiple continuous events with different themes. v29 increased number of stingers to 8.
Feature Requests
