berryv97
#1 Posted : Sunday, August 24, 2025 11:18:36 PM(UTC)
berryv97
OMT is not available as an API output option. Unlike NDI or SRT, which can be enabled (set to true) when active, OMT cannot be used in this way.
<output type="output" number="1" source="Output" ndi="True"/>
<output type="output" number="2" source="Mix" mix="4"/>
<output type="output" number="3" source="Input" inputNumber="1"/>
<output type="output" number="4" source="MultiView" ndi="True"/>
pm
#2 Posted : Monday, August 25, 2025 1:47:06 AM(UTC)
pm
Was thanked: 33 time(s) in 28 post(s)
And I would additionally suggest to not remove the key when they are set to false. Like on other locations in the xml when the value of a key is false.
<output type="output" number="1" source="Output" ndi="True" omt="True" srt="False"/>
thanks 1 user thanked pm for this useful post.
berryv97 on 8/25/2025(UTC)
