ken5o
#1 Posted : Friday, August 22, 2025 12:39:12 PM(UTC)
ken5o
Japan
I’m using vMix with an UltraStudio HD Mini to output Fill (59.94i / straight) into a DeckLink Duo 2, connected to SDI3.
In vMix, I add Device 2 (the Fill output from the UltraStudio HD) as an input. When I check the waveform of this input, the white level seems to be slightly lower.
Do I need to specify or configure something when bringing this signal into vMix?
On the output side, vMix External Output is set to UYVY. When I check the UltraStudio HD Mini output directly on a monitor, the white level looks correct, so I assume this issue is related to vMix settings.
Is there something required to ensure that the input signal level matches the original output level?
Thank you in advance!
