InstantReplayGO
#1 Posted : Tuesday, August 19, 2025 5:57:14 AM(UTC)
InstantReplayGO
Brazil
Was thanked: 7 time(s) in 2 post(s)
To further optimize the workflow and bring functionalities similar to those found in systems like EVS and Dynno, I would like to suggest the implementation of the following shortcuts:
* ReplayCuePoint: (Today I use MarkInMarkOut with 1s) - Works like a "mark" in video editing software. Marks a point in the timecode so that the user can return to it and other marked points, creating clips more quickly, without the need to mark "in" and "out" all the time. Essential in events with fast information.
* ReplayLastCuePoint: (Similar to EVS) - When pressed, selects the last "cue point" created and, with each new press, jumps from the last to the first "cue point" created, facilitating navigation between points of interest.
* ReplayFindClips: In the clip manager, add a shortcut that puts the focus on the search field, allowing the user to type the tag of a clip and locate it quickly, without the need to use the mouse.
* ReplayGoToInPoint and ReplayGoToOutPoint: (EDIT) Has on ReplayJumpToSelectedInPoint and ReplayJumpToSelectedOutPoint "thanks"
I believe that these shortcuts, although they seem simple, can bring a significant gain in productivity for vMix Replay users, making the software even more competitive in the live video production market.
