ask
#1 Posted : Friday, February 6, 2015 8:47:42 PM(UTC)
ask
Hi Martin.
On testing the replay module on my test laptop I received this error when trying to activate the record function on the replay module.
ReplayTick
Can you explain it please?
Andrew
#2 Posted : Friday, February 6, 2015 9:57:07 PM(UTC)
Was thanked: 4735 time(s) in 1624 post(s)
What is the full error message? There will be a log file in the replay session folder
that provides more information.
ask
#3 Posted : Saturday, February 7, 2015 9:15:25 AM(UTC)
ask
2015-02-06 11:43:12,ConfiguredAudio: 5
2015-02-06 11:43:12, SampleRate: 48000
2015-02-06 11:43:12, BitRate: 16
2015-02-06 11:43:12, Channels: 2
2015-02-06 11:43:12, Float: False
2015-02-06 11:43:12, Delay: 40
2015-02-06 11:43:12,ConfiguredCamera: 1
2015-02-06 11:43:12, Format: X8R8G8B8
2015-02-06 11:43:12, Pitch: 7680
2015-02-06 11:43:12, Delay: 0
2015-02-06 11:44:54,StartRecording
2015-02-06 11:44:54, Cameras: 1
2015-02-06 11:44:54, Size: {Width=1920, Height=1080}
2015-02-06 11:44:54, FrameRate: 25
2015-02-06 11:44:54, Interlaced: UpperFieldFirst
2015-02-06 11:44:57,StreamError: 1
2015-02-06 11:44:57,System.NullReferenceException: Object reference not set to an instance of an object.
at xzzzzl.t(wzzzzt a, Boolean a, Byte[] a, Int32 a, Int32 a)
at xzzzzl.s(wzzzzt a, Int64 a)
at xzzzzl.q()
2015-02-06 11:44:57,StopRecording
2015-02-06 11:44:57,Statistics
2015-02-06 11:44:57, Camera 1
2015-02-06 11:44:57, Dropped Frames
2015-02-06 11:44:57, -DueToCPUOrDisk: 56
2015-02-06 11:44:57, -SourceTooSlow: 0
2015-02-06 11:44:57, -SourceTooFast: 0
2015-02-06 11:44:57, -AVSync: 0
2015-02-06 11:44:57, Total: 56
2015-02-06 11:44:57, Dropped Samples
2015-02-06 11:44:57, -DueToCPUDOrDisk: 0
2015-02-06 11:44:57, Total: 0
2015-02-06 11:44:57, Camera 5
2015-02-06 11:44:57, -DueToCPUOrDisk: 0
2015-02-06 11:44:57, -SourceTooSlow: 4
2015-02-06 11:44:57, Total: 4
2015-02-06 11:45:03,StartRecording
2015-02-06 11:45:03, Cameras: 1
2015-02-06 11:45:03, Size: {Width=1920, Height=1080}
2015-02-06 11:45:03, FrameRate: 25
2015-02-06 11:45:03, Interlaced: UpperFieldFirst
2015-02-06 11:45:07,StreamError: 1
2015-02-06 11:45:07,System.NullReferenceException: Object reference not set to an instance of an object.
at xzzzzl.q()
2015-02-06 11:45:07,StopRecording
2015-02-06 11:45:07,Statistics
2015-02-06 11:45:07, Camera 1
2015-02-06 11:45:07, Dropped Frames
2015-02-06 11:45:07, -DueToCPUOrDisk: 146
2015-02-06 11:45:07, -SourceTooSlow: 0
2015-02-06 11:45:07, -SourceTooFast: 0
2015-02-06 11:45:07, -AVSync: 0
2015-02-06 11:45:07, Total: 146
2015-02-06 11:45:07, Dropped Samples
2015-02-06 11:45:07, -DueToCPUDOrDisk: 0
2015-02-06 11:45:07, Total: 0
2015-02-06 11:45:07, Camera 5
2015-02-06 11:45:07, -DueToCPUOrDisk: 0
2015-02-06 11:45:28,StartRecording
2015-02-06 11:45:28, Cameras: 1
2015-02-06 11:45:28, Size: {Width=1920, Height=1080}
2015-02-06 11:45:28, FrameRate: 25
2015-02-06 11:45:28, Interlaced: UpperFieldFirst
2015-02-06 11:45:32,StreamError: 1
2015-02-06 11:45:32,System.NullReferenceException: Object reference not set to an instance of an object.
at xzzzzl.q()
2015-02-06 11:45:32,StopRecording
2015-02-06 11:45:32,Statistics
2015-02-06 11:45:32, Camera 1
2015-02-06 11:45:32, Dropped Frames
2015-02-06 11:45:32, -DueToCPUOrDisk: 252
2015-02-06 11:45:32, -SourceTooSlow: 1
2015-02-06 11:45:32, -SourceTooFast: 0
2015-02-06 11:45:32, -AVSync: 0
2015-02-06 11:45:32, Total: 253
2015-02-06 11:45:32, Dropped Samples
2015-02-06 11:45:32, -SourceTooSlow: 0
2015-02-06 11:45:32, -DueToCPUDOrDisk: 0
2015-02-06 11:45:32, Total: 0
2015-02-06 11:45:32, Camera 5
2015-02-06 11:45:32, -DueToCPUOrDisk: 0
2015-02-06 11:45:32, -SourceTooSlow: 5
2015-02-06 11:45:32, Total: 5
2015-02-06 11:45:58,StartRecording
2015-02-06 11:45:58, Cameras: 1
2015-02-06 11:45:58, Size: {Width=1920, Height=1080}
2015-02-06 11:45:58, FrameRate: 25
2015-02-06 11:45:58, Interlaced: UpperFieldFirst
2015-02-06 11:46:02,StreamError: 1
2015-02-06 11:46:02,System.NullReferenceException: Object reference not set to an instance of an object.
at xzzzzl.q()
2015-02-06 11:46:02,StopRecording
2015-02-06 11:46:02,Statistics
2015-02-06 11:46:02, Camera 1
2015-02-06 11:46:02, Dropped Frames
2015-02-06 11:46:02, -DueToCPUOrDisk: 346
2015-02-06 11:46:02, -SourceTooSlow: 0
2015-02-06 11:46:02, -SourceTooFast: 0
2015-02-06 11:46:02, -AVSync: 0
2015-02-06 11:46:02, Total: 346
2015-02-06 11:46:02, Dropped Samples
2015-02-06 11:46:02, -DueToCPUDOrDisk: 0
2015-02-06 11:46:02, Total: 0
2015-02-06 11:46:02, Camera 5
2015-02-06 11:46:02, -DueToCPUOrDisk: 0
2015-02-06 11:46:27,StartRecording
2015-02-06 11:46:27, Cameras: 1
2015-02-06 11:46:27, Size: {Width=1920, Height=1080}
2015-02-06 11:46:27, FrameRate: 25
2015-02-06 11:46:27, Interlaced: UpperFieldFirst
2015-02-06 11:46:32,StreamError: 1
2015-02-06 11:46:32,System.NullReferenceException: Object reference not set to an instance of an object.
at xzzzzl.q()
2015-02-06 11:46:32,StopRecording
2015-02-06 11:46:32,Statistics
2015-02-06 11:46:32, Camera 1
2015-02-06 11:46:32, Dropped Frames
2015-02-06 11:46:32, -DueToCPUOrDisk: 452
2015-02-06 11:46:32, -SourceTooSlow: 0
2015-02-06 11:46:32, -SourceTooFast: 0
2015-02-06 11:46:32, -AVSync: 0
2015-02-06 11:46:32, Total: 452
2015-02-06 11:46:32, Dropped Samples
2015-02-06 11:46:32, -DueToCPUDOrDisk: 0
2015-02-06 11:46:32, Total: 0
2015-02-06 11:46:32, Camera 5
2015-02-06 11:46:32, -DueToCPUOrDisk: 0
2015-02-06 11:48:45,StartRecording
2015-02-06 11:48:45, Cameras: 1
2015-02-06 11:48:45, Size: {Width=1920, Height=1080}
2015-02-06 11:48:45, FrameRate: 25
2015-02-06 11:48:45, Interlaced: UpperFieldFirst
2015-02-06 11:48:46,StreamError: 1
2015-02-06 11:48:46,System.NullReferenceException: Object reference not set to an instance of an object.
at xzzzzl.q()
2015-02-06 11:48:46,StopRecording
2015-02-06 11:48:46,Statistics
2015-02-06 11:48:46, Camera 1
2015-02-06 11:48:46, Dropped Frames
2015-02-06 11:48:46, -DueToCPUOrDisk: 465
2015-02-06 11:48:46, -SourceTooSlow: 0
2015-02-06 11:48:46, -SourceTooFast: 0
2015-02-06 11:48:46, -AVSync: 0
2015-02-06 11:48:46, Total: 465
2015-02-06 11:48:46, Dropped Samples
2015-02-06 11:48:46, -DueToCPUDOrDisk: 0
2015-02-06 11:48:46, Total: 0
2015-02-06 11:48:46, Camera 5
2015-02-06 11:48:46, -DueToCPUOrDisk: 0
#4 Posted : Saturday, February 7, 2015 10:27:06 AM(UTC)
Thanks,
It is reporting the camera format as X8R8G8B8 which Instant Replay does not support.
I'm assuming you have set Camera 1 to output?
If so make sure the format under Settings -> Performance -> Output Format is set to UYVY
as RGB32 is not recommended.
ask
#5 Posted : Saturday, February 7, 2015 5:44:34 PM(UTC)
ask
The Camera is a Logitech 920. It is a default install of vMix.
Camera 1 is set to the Logitech not to output.
