TommyBEADG
#1 Posted : Tuesday, July 15, 2025 4:39:23 AM(UTC)
TommyBEADG
This is not a native effect function in Vmix. Has anyone tried to do this through some sort of app? I have not found anything Are there any recommendations on an app, or editor that can do this for live video? Thanks.
nikosman88
#2 Posted : Tuesday, July 15, 2025 6:39:10 PM(UTC)
nikosman88
Greece
Obs trail effect
spinfold
#3 Posted : Tuesday, July 15, 2025 6:54:46 PM(UTC)
spinfold
Was thanked: 14 time(s) in 14 post(s)
If I've understood you correctly, this is actually quite easy to do in vMix.
1) Add a Mix input
2) Put whatever source you want to echo into that Mix
3) Set that Mix input as a spare Output (say Output 4) and turn on NDI
4) As a separate input, add the NDI source of Output 4
5) Delay this new input by, say, half a second
6) In a new blank input, add the original Mix input, and the NDI input, as layers 1 and 2, and adjust opacity of each to suit.
7) Put this new input into PGM
TommyBEADG
#4 Posted : Wednesday, July 16, 2025 2:53:27 AM(UTC)
TommyBEADG
Thank you for the advice! Will be trying it out soon and will circle back with the results. Appreciate it. Tomi.
